vince56
unregistriert
1
Mittwoch, 2. Oktober 2019, 14:08
Trunk Water leak
some homeowners watch water running from the inside of the trunk when they open it. We have found the cause and the solution to remedy it. It is important to do this, this water can cause corrosion and / or camera or trunk button failures. A complete tutorial has been done to repair, auT300C could translate it. But it is simply the seal around the 3rd stop light which is deteriorating, just put another.
If you have some pellets taped to the 4 corners of the luggage compartment, remove them, a surprise awaits you, take an umbrella.
You can found pictures and tutorial in our Facebook (must be register, in french) : https://www.facebook.com/notes/lancia-th…07988579669180/
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »vince56« (2. Oktober 2019, 15:22)
Donnerstag, 3. Oktober 2019, 07:03
thanks.
I am going through it on the weekend.
vince56
unregistriert
3
Donnerstag, 3. Oktober 2019, 08:57
To show you what's happen if water go throught the Light.
